XM Studios Iceman 1/4 Statue
GHeroes European Master Distributor Facebook
компания:
XM Studios
Официальный и эксклюзивный европейский дистрибьютор:
GHeroes European Shop
Информация
ХУДОЖНИКИ: Philip Herman (Sculpt)
Размер товара: 60 cm L X 40 cm B X 52 cm H
ограничение: MTO
"Scott, I don't ever say this, but you-freaking-rock!"
"XM Studios is excited to present our next Marvel Premium Collectibles series statue, Iceman! Literally, the coolest mutant is immortalized in amazingly detailed 1:4 scale cold-cast porcelain. Each painstakingly handcrafted statue is individually hand-painted with the highest possible quality finish. Crafted in a specially developed cold-cast polyresin material for the first time in all of XM’s creations, this special material was researched and developed together with the manufacturing factory’s senior engineering teams to achieve a realistic frosted ice effect (instead of common clear resin) that is durable and original to XM. The raw material is more costly to develop due to the special attributes but hey, Iceman deserves the best ice materials! Iceman is designed in a dynamic pose on a ice slide, showing his abilities atop a Danger Room themed base!"
STGCC 2018
STGCC 2018
