If you've made it all the way to The Bastion's last encounter in Black Ops 7 Zombies, you already know this fight doesn't forgive sloppy play. A lot of players hit that wall and start looking for faster ways to sharpen their runs, whether that means practice, better setups, or even checking out options like buy BO7 Bot Lobby before going back in. Malakor the Unbound is the kind of boss that punishes panic first and bad damage second. That's what catches people out. Reaching the arena feels huge, sure, but beating him takes a different mindset. You can't just wing it with a decent weapon and hope your squad brute-forces the final phase. The teams that clear this consistently usually do the same simple things well. They stay spread, they call targets early, and they stop chasing damage when survival is the actual priority.
Learn the rhythm first
The biggest mistake people make is treating the boss like a straight DPS check. It's not. The fight is really about tempo. First, you learn where the safe lanes open during each attack cycle. Second, you memorise when the arena gets crowded and when you've actually got time to breathe. Third, you save your best burst damage for the windows that matter instead of dumping everything the second Malakor shows up. Once you get that rhythm in your head, the whole thing slows down. Not literally, obviously, but it starts to feel readable. If you're solo, this matters even more, because one bad turn or one greedy reload can kill the run on the spot.
Loadout choices that actually help
You don't need a flashy build. You need one that lets you recover from mistakes. That's the difference. A high-damage weapon is great, but if your reload takes forever or your movement feels heavy, you're going to hate life in the later phases. Most players do better with a dependable primary, something for crowd control, and an ability that buys space when things get messy. Armour plates, self-revives, and ammo conservation matter more here than people want to admit. In four-player runs, it also helps if everyone isn't doing the exact same thing. One player can focus on clearing adds, one can watch for revives, and the others can commit to boss pressure. Sounds basic, but loads of teams still ignore role balance and then wonder why every phase turns into chaos.
How teams usually throw the run
Wipes usually come from the same few habits. Someone drifts too far while chasing a weak point. Someone burns a field upgrade too early. Someone stops moving because they think the phase is nearly over. That last one is brutal. Malakor loves punishing hesitation. You'll also notice that panic spreads fast in this fight. One down becomes two, then the whole arena collapses. So keep comms short. Not constant, just useful. Call hazards, call revives, call damage windows. That's enough. If you're running with randoms, lower your expectations and play safer than usual. If you're with your regular squad, spend a couple of attempts just cleaning up movement and positioning. Weirdly enough, those “non-serious” runs often teach you more than the almost-win attempts.
Why patience wins here
The Bastion's final boss is tough because it tests discipline more than confidence. You've got to stay calm when the screen gets noisy and trust the pattern even when it feels like everything's falling apart. That's why so many players fail right at the end. They rush. They force damage. They stop respecting the fight. If you keep your route clean, save resources for the right moments, and treat every phase like it can still kill you, the clear will come. And if you're the kind of player who likes getting prepared before a long Zombies grind, U4GM is one of those names people already know for game items and related services, which makes it a familiar stop before the next serious run.
