Интрига раскрылась , но результат похоже не тот который все ждали... новым MMS оказался очередной ЖЧ
The Iron Man Mark XLV
Высота: 31 см
Выход: 2-3 квартал 2016.
Юбилейный 300й релиз... от HoT Toys
Фигурка Железного человека Марк 45 формата 1/6 по мотивам фильма "Мстители. Эра Альтрона"
•Authentic and detailed likeness of Mark XLV in Avengers: Age of Ultron
•Approximately 12 inches / 31 cm tall
•Over 30 points of articulation
•Contains diecast material
•Metallic red, gold and silver colored painting on armor with weathered effects
•LED light-up eyes (white light, battery operated)
•LED-lighted circle-shaped Arc Reactor with hexagonal-shaped indent on chest (white light, battery operated)
•One interchangeable battle damaged chest armor
•One (1) pair of interchangeable forearm laser weapons
•Four (4) pairs of interchangeable palms including:
•One (1) pair of palms with articulated fingers and light-up repulsors (white light, battery operated)
•One (1) pair of fists
•One (1) pair of battle palms with light-up repulsor (white light, battery operated)
•One (1) pair of palms with realistic thrust fire effect
•Fully deployed air flaps at back of the armor
•Articulation on waist armor which allows for flexible movement
•Two (2) realistic thrust fire accessories
•Specially designed diorama figure base featuring a detachable damaged Ultron Sentry (Prime)
The Iron Man Mark XLV is the 300th Hot Toys Movie Masterpiece Series collectible figure and it is also the latest addition to our MMS Diecast Series which the collectible figures are made of diecast material, and realistically designed to look even more like the armor as it appears in the film.
