Вы здесь » Клуб Art & Toys » Новости о дизайнерских фигурках » Blаckp. Black 13 Park - Bear Heavy Armour Resistance Combat Troop
Сообщений 1 страница 10 из 55
Фигурка Bear Heavy Armour Resistance Combat Troop от Black 13 Park
Цена около 700 USD
Почта +
Выход в апреле 2021
Инфа на анг
Heavy Armor Defense and Ground Suppression Force (Brown Bear) is eighth Black Laborary Series figure.
1) Animal Genes & It’s Attributes:
Ingesting brown bear gene into the body of an excellent army member so that he can have a strong physique of a browm bear which has anti-impact ability. He can resist light to moderate armed firepower.
2) Task Responsibity:
Heavy Armor Defense and Ground Suppression Force mainly responsible for resisting the light and medium armed fire damage of the enemy during execution of a mission. They are also required to quickly establish a high mobility defense on the front line and cooperate with the reloading attack force to carry out mandatory tactical attacks and heavy firepower annihilation.
3) Weapon and Equipment:
He is equipped with high-strength armour body gear to resist against light to medium sized firepower. The armour gives maximum protection to the body without affecting the range of movement. The chest armor is partially loaded with small-launched grenades which are used to clear small scale enemies, and armed vehicles.
He has also a large tactical shield to improve the high mobility defense level of the fire suppression stage. Large tactical shield improves his whole body defense mechanism to a state of without flaws. High powered flash light at the front of the shield can make enemy stunned instantly and causes short-term vision loss.
His main weapon is a large size reloaded special grenade launcher equipped with high explosive grenades. Since the weapon is only loaded with fewer bullets, it is only used to remove small scale enemies and armed vehicles.
Additional weapon includes is a portable and compact revolver which can be used flexibly with tactical shield. Shoulder armour are designed to be used as a hand defense shield in the form of a brown bear attack.
4) Experimenter Information:
Experiment No.: P01 (Heavy Armor Defense and Ground Suppression Force)
Experimenter Name: Adrian (Former European Military Police Force)
5) Personal Information:
Adrian is a European. Before joining the German Army, he was a member of Military Police Department whose job is to suppress rioters. During his time with the German Army and because of his relatively strong and burly body, he was selected into the Heavy Armor Defense and Ground Suppression Force and genetically implant with brown bear genes under Black Laborary project.
Перевод Гугл
Медвежья фигура под Black Laborary Series наконец-то здесь !!! Он - Бурый Медведь, чья военная позиция находится под боевым отрядом сопротивления тяжелой броне. В течение 7 лет многие коллекционеры ожидали, что будет выпущена фигура медведя, и она считается обязательной фигурой животного в серии Black Laborary.
Дизайн и покраска этого шедевра - это совокупный результат 7-летнего опыта Black 13 Park в создании фигур.
Бурый медведь имеет более смелый дизайн брони и механического оборудования, а также имеет большинство аксессуаров по сравнению со всеми предыдущими показателями в серии Black Laborary на данный момент.
Фигура может быть либо полностью вооружена, либо переключаться в режим тяжелой брони. Впервые в 2020 году для бурого медведя было спроектировано и разработано новое крепкое тело, отражающее его крепкое и мощное телосложение. Не только дизайн имеет сильный контраст со всем предыдущим дизайном тела, внутренний орган и анатомия бурого медведя также были переработаны, что позволяет коллекционерам получить совершенно новый опыт Black Laborary.
Пакет будет включать в себя:
скульптура человеческой головы, скульптура человеческой головы анатомии и скульптура головы черепа соответственно. Сюда также входят 3 скульптуры головы медведя, скульптура головы с выражением сердитого медведя, скульптура головы с серьезным выражением лица и скульптура головы медведя с анатомией. Там будет 2 шейных разъема, чтобы коллекционеры могли использовать его для демонстрации тела медведя, а также для другой желаемой позы по вкусу коллекционера.
«Путешествие потерянной кости» продолжается: «Путешествие потерянной кости» в этой серии представляет собой череп медведя, который можно поместить в анатомическую голову медведя или поместить в контейнер для кости для сбора и демонстрации. Из-за небольшой формы черепа медведя компания Black laborary специально разработала новую бутылку с костяным контейнером для таких маленьких черепов, чтобы обогатить опыт коллекционеров при сборе и демонстрации серии утраченных костей. Эта бутылка с костяным контейнером также подходит для предыдущего черепа кошки и черепа лягушки. В то же время, помимо контейнера для костей для медведя, Black 13 Park предоставит еще один дополнительный контейнер для бутылок в знак признательности, чтобы поблагодарить всех коллекционеров, которые приобрели Black Laborary Series Cat and Frog. Таким образом, один контейнер можно использовать для черепа медведя, а другой - для черепа кошки или лягушки.
Силы защиты тяжелой брони и подавления земли (бурый медведь) - восьмая фигура Черной Лаборарной Серии.
1) Гены животных и их атрибуты:
Внедрение гена бурого медведя в тело превосходного военного, чтобы он мог иметь крепкое телосложение бровь-медведя, обладающего противоударной способностью. Он может противостоять легкой и умеренной вооруженной огневой мощи.
2) Задача Ответственность:
Силы обороны и наземного подавления тяжелой брони в основном отвечают за сопротивление легкого и среднего вооруженного урона от огня противника во время выполнения миссии. От них также требуется быстро установить оборону с высокой мобильностью на линии фронта и сотрудничать с силами перезарядки для выполнения обязательных тактических атак и уничтожения тяжелой огневой мощи.
3) Оружие и снаряжение:
Он оснащен высокопрочным бронежилетом, чтобы противостоять легкой и средней огневой мощи. Броня обеспечивает максимальную защиту тела, не влияя на диапазон движения. Нагрудный доспех частично загружен гранатами малого калибра, которые используются для уничтожения мелких врагов и вооруженных транспортных средств.
У него также есть большой тактический щит, чтобы улучшить высокий уровень защиты подвижности на стадии подавления огня. Большой тактический щит повышает его защитный механизм всего тела до состояния без изъянов. Мощная вспышка на передней части щита может мгновенно оглушить противника и вызвать кратковременную потерю зрения.
Его главное оружие - перезаряжаемый гранатомет большого размера, оснащенный гранатами со взрывчаткой. Поскольку в оружие загружено меньше пуль, оно используется только для удаления мелких врагов и вооруженных транспортных средств.
Дополнительное оружие включает в себя портативный и компактный револьвер, который можно гибко использовать с тактическим щитом. Наплечная броня предназначена для использования в качестве защитного щитка для рук в виде атаки бурого медведя.
4) Информация для экспериментатора:
Эксперимент № P01 (Силы защиты тяжелой брони и наземного подавления)
Имя экспериментатора: Адриан (бывшие европейские военные полицейские силы)
5) Личная информация:
Адриан - европеец. До прихода в германскую армию он был сотрудником департамента военной полиции, задачей которого является подавление беспорядков. Во время его пребывания в немецкой армии и из-за его относительно сильного и крепкого тела он был выбран в Силу Защиты Тяжелой Брони и Подавления Земли и генетически имплантирован генами бурого медведя в рамках проекта Black Laborary.
https://i.imgur.com/IYYqUyw.jpg
https://i.imgur.com/G2754WE.jpg
https://i.imgur.com/5If9P2g.jpg
https://i.imgur.com/LFT7zI3.jpg
https://i.imgur.com/nvbtkH0.jpg
https://i.imgur.com/hPhCo7u.jpg
https://i.imgur.com/eL2mGVy.jpg
https://i.imgur.com/wJcoj16.jpg
https://i.imgur.com/0sqc1ss.jpg
https://i.imgur.com/StR4I9I.jpg
https://i.imgur.com/NChCTmZ.jpg
https://i.imgur.com/9VhagLp.jpg
https://i.imgur.com/IYcF6Jh.jpg
https://i.imgur.com/5zpQ0Qi.jpg
https://i.imgur.com/zBmVYGu.jpg
https://i.imgur.com/Z8SM7AS.jpg
https://i.imgur.com/TL2lOMI.jpg
https://i.imgur.com/j75J0CT.jpg
https://i.imgur.com/3m1DGxj.jpg
https://i.imgur.com/u7mpFT2.jpg
https://i.imgur.com/AAroY6a.jpg
https://i.imgur.com/CshWSJo.jpg
https://i.imgur.com/EBH2LvH.jpg
https://i.imgur.com/P0kynf8.jpg
https://i.imgur.com/LJsTDeQ.jpg
https://i.imgur.com/Su0tFaT.jpg
Фото Медведя
https://i.imgur.com/dodq0N4.jpg
https://i.imgur.com/KttNzD5.jpg
https://i.imgur.com/63aUoUo.jpg
https://i.imgur.com/B2J6QLU.jpg
https://i.imgur.com/g4VrD0M.jpg
https://i.imgur.com/cHqZ1IR.jpg
https://i.imgur.com/jytGvSY.jpg
https://i.imgur.com/1JDHwxv.jpg
https://i.imgur.com/XvZEftI.jpg
https://i.imgur.com/9oxA3AD.jpg
https://i.imgur.com/c2ekObd.jpg
https://i.imgur.com/zBjcvS8.jpg
https://i.imgur.com/BJMaS0Q.jpg
https://i.imgur.com/IuixZK8.jpg
https://i.imgur.com/8GjCXph.jpg
https://i.imgur.com/ACR1DBU.jpg
https://i.imgur.com/r4pb9MJ.jpg
https://i.imgur.com/w1pemGd.jpg
https://i.imgur.com/mpkMRM3.jpg
https://i.imgur.com/51U42Bs.jpg
https://i.imgur.com/WAGJBjI.jpg
https://i.imgur.com/cjgXdpM.jpg
https://i.imgur.com/Faltk8u.jpg
Фото аксов и скульптов
https://i3.imageban.ru/out/2020/06/11/08a76ad85b965cfe1d79bdd484036703.jpg
https://i1.imageban.ru/out/2020/06/11/b0d8ffbd8186398c12984c4bc314c032.jpg
https://i4.imageban.ru/out/2020/06/11/b27c745cb2df69029f3f18a571b7a104.jpg
https://i4.imageban.ru/out/2020/06/11/bcdc32cd1dc639877ea4b3bb03aa676c.jpg
https://i4.imageban.ru/out/2020/06/11/8c9350aaff9526140ea8f89080afbe3e.jpg
https://i6.imageban.ru/out/2020/06/11/2ae5c0f054525b0c99e0c096dac40ace.jpg
https://i2.imageban.ru/out/2020/06/11/68140e07c5811905991918c0f60e9368.jpg
https://i2.imageban.ru/out/2020/06/11/4de07b88ffea591c2536936da82ab3c7.jpg
https://i4.imageban.ru/out/2020/06/11/98c3cb59717b1fbead4113d560b260a7.jpg
https://i6.imageban.ru/out/2020/06/11/2c8f436cfa49d83c3c3af2272d288dac.jpg
https://i6.imageban.ru/out/2020/06/11/057984e161c84daecfad723d050a6f14.jpg
https://i4.imageban.ru/out/2020/06/11/54fbbf04c7b8dedc84c85fb6b028ddf7.jpg
https://i1.imageban.ru/out/2020/06/11/3f53e8f4a856b17ed596c8205866a555.jpg
https://i1.imageban.ru/out/2020/06/11/3f817f9f2217de8cf8a6873ec116cb28.jpg
https://i2.imageban.ru/out/2020/06/11/7c84f21e5f12d93671603cd79618efd7.jpg
https://i5.imageban.ru/out/2020/06/11/01afbc1e104faa3fb4bbe60f8f9fda9f.jpg
https://i4.imageban.ru/out/2020/06/11/d34bdfcdcd1df146340c61f20e72c69d.jpg
https://i5.imageban.ru/out/2020/06/11/cd1f6aa0ef521ef1904a555a516b1e2e.jpg
https://i5.imageban.ru/out/2020/06/11/20f1d4916b5d3d0913a69c9acbfc7f65.jpg
https://i1.imageban.ru/out/2020/06/11/a8872db4aae0e834cfdadda8686a9101.jpg
https://i2.imageban.ru/out/2020/06/11/85a46c371de5cadba9daa423afe391d1.jpg
https://i6.imageban.ru/out/2020/06/11/b98155d1342a086191f2ef03ed2c185b.jpg
https://i4.imageban.ru/out/2020/06/11/3d48e0b2e8e1b833ff9ad7f595cde9e4.jpg
https://i1.imageban.ru/out/2020/06/11/2e48da7251bcfef6f63439e1c46ca73d.jpg
https://i5.imageban.ru/out/2020/06/11/6b036cfe0c1b8e2dc57a80d4cf113856.jpg
https://i5.imageban.ru/out/2020/06/11/2b88818e658074f3088f2146e3b1701b.jpg
https://i2.imageban.ru/out/2020/06/11/0630884485ee64780f3808bbfb581325.jpg
https://i3.imageban.ru/out/2020/06/11/73b02f50517c70fb95e6e399c1f1cf90.jpg
https://i2.imageban.ru/out/2020/06/11/9d0fe7cefb568ad2104f3f15340dfa3e.jpg
https://i5.imageban.ru/out/2020/06/11/36c3557f640a273bb4ee9b4e9c55ab31.jpg
https://i4.imageban.ru/out/2020/06/11/314ce2c450543dfbe2d054080cd94630.jpg
https://i5.imageban.ru/out/2020/06/11/ab96059b1594ed8faf1a0f289f12abfa.jpg
https://i4.imageban.ru/out/2020/06/11/aea0314f6122174feb32ef3e42e94788.jpg
https://i5.imageban.ru/out/2020/06/11/48d1b49a7233753adc05e4b925ddacad.jpg
https://i2.imageban.ru/out/2020/06/11/923f3e2ab7cd56d430899422320cef5d.jpg
https://i5.imageban.ru/out/2020/06/11/97ee16d550d10f8c36851eac1e42e476.jpg
https://i5.imageban.ru/out/2020/06/11/604a40cba523e11c84bb01b9adbbf11e.jpg
Олень, Лис, Волк, Воробей, Кот, Лягушка, Сокол и теперь Медведь
Номер 8, в остатке 5 штук  http://forumstatic.ru/files/0014/cc/2e/77277.png
Медведь получился очень боевой и сверх бронированный  http://forumstatic.ru/files/0014/c1/42/27472.gif
Скульпт выдержан в стиле других фигурок из этой серии. Неплохо
Жаль, что в арсенале не так много оружия и нет чего то крупного сверх мощного как было у кота или Оленя.
Ножей бы ему тоже ...
https://i.imgur.com/6RXzIB6.jpg
Стараюсь всеми силами не обращать внимание на данную серию, так как хотелок хватает на год вперед. Но чем больше углубляюсь в мир подобных фигурок, тем больше пониманию - насколько же они охренительные.
Назревает беда.. если купить одну, слезть с этой иглы уже вряд ли получится, так как уровень исполнения, качества, дизайна и самой идеи - на высоте. http://forumstatic.ru/files/0014/c1/42/49953.gif
Могли бы и по оригинальней сделать, форма напоминает бойцов сопротивления из «Звёздные войны. Эпизод VI: Возвращение джедая» и бойцов корпорации Хронос из Гайвера.
Касаемо это серии, то она уникальна и пользуется наибольшим интересом у публики.
Фигурок в серии всего 13 штук (не считая спешл изданий)
Вроде бы немного и вполне возможно собрать их всех, учитывая, что они выходят раз в год.
Но цена иногда бьёт по голове ..  http://forumstatic.ru/files/0014/c1/42/16074.gif
Однако, когда получаешь такую арт фигурку, то все печали связанные с тратами меняются на радость от обладания качественной и редкой фигуркой.
Лично я стал коллекционировать такие фигурки один из первых в РФ и за все эти годы ни разу не пожалел.
Коллекционирование фигурок Black 13 Park это редкая возможность порадоваться хобби и ощутить именно соль коллекционирования, здесь не просто радость в том, что ты покупаешь качественную фигурку как Робокопа, ЖЧ дайкаст, но добавляешь в коллекцию редкий , дорогой и интересный авторский экспонат.
Мало, кто делает сложные дизайнерские фигурки и при этом успешно, большинство норовят сделать всё попроще и подешевле, так как чем проще, тем легче не разочаровать. Сложные дизайны редко получаются гармоничными, стоят дорого и если это не гармоника, то это провал.
Данная серия и её мастер большое исключение. Фигурки - Мини шедевры с которыми сложно конкурировать другим дизайнерским сериям, как сейчас, так и потом. После выхода этой эпик серии, цены будут ещё выше, а поиски трудней.
Видео презентация
Детальки
https://i5.imageban.ru/out/2020/06/11/641a8acd701fda0b841ac67d5a22b5ca.jpg
Такие дела
https://i.imgur.com/4Kf2HVb.png
Разные сравнения и отсылки
https://sun1-99.userapi.com/eISLnJe_NeJfOQ3r3NtQHrcWB2FeF1CSp6BF3w/xNzZ_VUkGis.jpg
https://sun1-17.userapi.com/2y0COk71FJu5I90-MEYTKQlxfWseVrr9h9xb1w/XCvgWxz38Bo.jpg
https://sun1-18.userapi.com/JrP_DGkY8S1VsXYHfO7_pboMoZ-bTU3F0z3rBQ/2rPG-UiIVUs.jpg
https://sun1-29.userapi.com/20tDyx4plKM4JLLu2z96atsut-AIz9hQTsQocw/N2MsFGgXAy0.jpg
https://sun1-96.userapi.com/keyzrdWG_PWfcWkAvY-cd75g770TQW_kUHkNAQ/X5MjH-_ts9E.jpg
https://sun1-89.userapi.com/ZEUq9RSqxM_ACzPheW1t3aKxhCYE859g9kboVg/V1M1MktpdN4.jpg
ИТОГО С ДОСТАВКОЙ ВЫХОДИТ 740 USD
Кому нужен купон со скидкой 40 USD , пишите в ЛС.
+ Почту выбераем 90 USD, а не EMS 120.
ССылку дам
В маге осталось 75 штучек.
P.s
По мере уменьшения прайс может подняться.
Вылитый сапер
